RPM going CRAZY!!!
2nd again, my friend's bmw did this after we swapped engines. it would rev to 3500 then to 0, as long as he wasnt on the gas
turned out his idle control valve was bad, replaced that and there was no problems
thanks phonix.... your engine looks really clean.. how much for those hose??..
anyways. follow on what you're saying. and i got another pic. thanks to Mcillgotte... he took a picture of his.. even tho it's mod..
i went and look at my own.. if i circled it right.. how am i to clean that?? take the whole metal pieace off and clean it??.. wish someone could do a DIY on ES300 IAC cleaning..
Mcelligott.. i'm glad i fould your picture while searching on google , thought you would of teach a member how to clean the IAC the right way... .. anyways.. the picture of the hose you build looks cool. might start a trend..
if you're talking about the hose in the picture that i circle.. i checked, no broken or crack hose.. yeh i kinda understand where those hose are from.. i think i can go to lowes and get a few hundred feets ... but the thing is.. where is the IAC located in that picture or is that whole metal pieace i circle is the IAC.... if so. see there's a pieace of metal, i think it's a gasket for that. if i am to take it off for cleaning. do i have to get a whole new gasket??..
