how to reset the maintance required light on es330
i was wondering how do you reset the maint light on my 2005 es330.... did a search but didnt fine anything....... thanks..........
Set your odometer window to ODO (not Trip A or Trip B). Without starting the engine, turn the key to the ON position. Press and hold the button next to the odometer window - the maintenance light will reset.
for some odd reason i tried it and it didnt work,,,,,,, are there any other alternatives to disconnecting the batter..... maybe i just did it wrong i dont know
Try this.
1. get in car, shut doors. put key in ignition and do not move it.
2. make sure you odometer is on total miles and not trip A or trip B. If it is not on total, then push the button right next to it to scroll through trips A and B and back to the total miles.
3. now take you finger off the button and wait a second.
4. With your left hand push that button in and hold it, DO NOT take you finger off it.
5. With your right hand turn the key to the ON position. DO NOT START the car.
6. Keep your finger on the button until the maint. reminder light flashes at you or goes out.
7. Turn the key back to off.
8. Take your finger off the button.
Now start the car normally, the maint. reminder light should be out.
If it doesn't work, repeat the procedure and reverse steps 7 and 8.
steviej
steviej
brucelee1
12-12-12 08:06 AM
durnil
11-16-04 10:48 AM
