The Free Mod Sieres: Part VI Acing Aerodynamics
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Background:
Aerodynamics. What can't be said? If they're better, you get better gas mileage (less resistance to moving through the air) while having the ability to accelerate faster...
Theory:
A stock Camry/ES 300 is pretty good from the factory.
Gen 1 ES 300 has a .32 drag coefficient, while having 21.88 ft ^2 of frontal area
Gen 3 Camry is .40 drag coefficient, while having 22.27 ft ^2 of frontal area
Good, but could be better!
ES 300's HP losses at X mph:
55mph = 7.8 horsepower
60mph = 10.1 horsepower
70mph = 16.0 horsepower
100mph = 46.7 horsepower
120mph = 80.7 horsepower
140mph = 128.1 horsepower
Camry's HP losses at X mph:
55mph = 8.4 horsepower
60mph = 10.9 horsepower
70mph = 17.3 horsepower.
100mph = 50.5 horsepower
120mph = 87.2 horsepower
140mph = 138.5 horsepower
Anything we can do to cut resistance is going to and increase gas mileage, and increase top speed (if you don't have an ECU limiter)
Roughly 1/3 of the drag on a modern car comes from the undercarriage! Ever seen your undercarriage??? Next to NOTHING has been done to help it out!!!
Percentage of Total Drag
Cooling package (including radiator, intercooler, oil cooler, etc) - 33.4%
Exterior - 31.7%
Front wheels - 13.1%
Rear wheels - 6.9%
Floor - 6.9%
Rear Axle - 3.1%
Engine - 3.1%
Front Suspension - 1.4%
Exhaust - 0.7%
Instructions:
Face it... The large front air damns on most body kits don't do crap for aerodynamics. (Let alone many people don't like how they look); while lip spoilers simply look ridiculous if you're not a Porsche running a 24 hour endurance race!
Let's decrease that by a big chunk!
Anyone that's ever changed their oil will recognize these as the tock under trays:
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-Stock.jpg)
We are going to replace those. You have a choise to make:
Plastic sign material (i.e. the large, fluted yard sign stuff) = $2.50, easy to make. Cut it, tape it together, bolt it up. Good to just "see if this crap actually works"
A sheet of ABS plastic (1/8" thick) = $50-100 Much stronger. This is actually a permanent solution. Cut to fit, use a heat gun and bend it into the shape you want.
Fiberglass Epoxy = $20-30. Many, many times harder to use. You must build a form first, then lay your fiberglass down, then epoxy it. One chance, but nothing is going to bust this!
Both fluted Plastic, and a large sheet of ABS can be found at sign shops. Just ask for any scrape 2' in depth, by whatever the width of your car is.
The easiest way to start, is to tape a large sheet of paper under your car, and trace out the general pattern. Transfer this to the material you are working with.
At this time there is an aerodynamic warning.
ĦĦĦDO NOT go farther behind than the front cross member!!!
If anything leaks from your engine, the plastic will be melted.
More importantly, what you do here DOES AFFECT your engine bay's ability to expel air. Run no covers and the temperature RISES because less air is able to pass through the radiator. Make too LARGE of a cover, and the same thing happens. Remember that some 90-95% of the air that enters your engine bay is expelled at the BACK-BOTTOM of the engine bay!
Be sure you leave extra material around the outsides. You want enough so that you can tuck it under the bottom of your body/bumper, that is rolled back plastic.
Tape the plastic signs together... WELL...
If you have ABS simply take a heat gun to the ABS and get it hot. You can then bend it evenly with something like a broom handle for even leverage.
I suggest re-using the stock bolt locations on any mounting method. No need to re-use them all. That's all the more you have to take back off during a fluid change!
(I'll skip fiberglass epoxy, because it takes a lot of practice... PM/IM/EMAIL for questions/tips on that. *Definitely* create an ABS Plastic one first so you have a ready-made mold.)
Here is my fiberglass epoxy one:
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-VS-Undertray.jpg)
[IMG]
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-3.jpg)
It is not visible to anyone at headlight height, or above.
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Front-car.jpg)
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-Front.jpg)
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-Front-Close.jpg)
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-Drivers.jpg)
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-pass.jpg)
Shape plays a very important part. If you form the thing down LOWER at the edges (in front of the tires), and roll it inwards. It will deflect air from part of the tire (from looking in front of the car) you can take a good chunk of drag away from the front tires. The trade off will slightly decrease stability in high wind. (Not enough for me not to go back and do it later)
(Unless you're a lucky, or smart; you'll want to remake an ABS one a few times, or make a few sign versions to find a "sweet spot")
Gas mileage on a 350m one way, all highway trip improved 4mpg at 75-80 mph, while top speed improved roughly 5 mph. 28mpg trip-average on a 3vz-fe that was previously never getting more than 24mpg under it's best highway day is a huge difference.
Now for the most important question! Why it is blue!?
Simply because I didn't have enough black covering, and blue was the darkest color I had on hand.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Part I Quicker Transmission Shifting
Part III Tuning the ECU
Part IV Cooling
Part V How to pick up MPG, and sleep with her too!
Part VII Cheap Water Injection
Part VIII Cheaply Monitoring the ECU & A/F Ratios
Theory:
Exterior - 31.7%
Rear wheels - 6.9%
Floor - 6.9%
Rear Axle - 3.1%
Engine - 3.1%
Exhaust - 0.7%
Instructions:
![](http://img.photobucket.com/albums/v414/Toysrme/Project%20Aerodynamic%20ES%20300/Undertray-2.jpg)
Part IV Cooling
gpreston24
ES - 7th Gen (2019-present)
15
04-23-19 05:20 PM
billm555
10-27-18 07:29 AM
