The Free Mod Series - Where's Part II ?
It was posted last year back here, disccused in several threads, and I didn't feel like re-posting it.
Toyota Nation is where I keep them up to date and add new ones. The only people that really get into modifying the v6's are v6 owners at TN, solara boards, and Toyota SUV/Truck people. No one in the ES world at that time was concerned with performance to any serious degree, 'cept sean and myself.
In a nutshell, it got edited as I tested dozens of different style air intakes on and off over a year.
Eventually the conclusion was reached that it is impossible to gain, or loose any measurable power by changing the intake on even highly modified stock bottom end - stock cam Toyota v6's. (That should be read as "you don't have a 300-340hp fully built N/A engine")
Said testing went from cheese holing the stock airbox, removing the SIR
custom CAI's - eventually it digressed into a study of how restrictive the large AFM was using an AFM bypass (think a very large vacuum leak, then re-tuning the AFM signal to where the car runs well again) -- which roughly halves the restriction caused by any air meter.
To simply running no filter at all.
No measurable amount of power was found to be gained or lost. Incidentally... The large AFM found on a 3vz-fe was found not to be restrictive, and will meter air accurately well past 300hp worth.
Currently, it's busy proving the fact that you can blow through (not suck through) a vane-flap Airflow Meter with a turbo acceptably well.
So here's part II in a nutshell...
Modify your intake on the basis of how much chrome you want in your engine bay, and what sound you want it to make, because you can't gain any power, or any performance from any intake modifications -- short of installing forced induction.
NYKnick101
08-21-13 12:42 AM
I8ABMR
08-07-10 07:28 AM
