leaky wheel
this was something i bought up a while back and finally a tire dealer was willing to spend enough time to find the leak. its leaking where the wheel and tire meet.......the seam. he said its a bend wheel or something is stuck on the wheel causing the leak. any advise or comment. thanks.
bad rim
need bead sealer
bad tire
nail in tire
picture would help
I had that same problem when i was on the stock rims, i found a burr that caused a slow leak, so i filed it off. Take the tire off the rim and look along the inside of the rim for any sharp pieces sticking out
thanks.
the tire is brand new and still had the leak thus i concluded its the rim. i will take the tire off to check to see if its bend or burr. again thanks.
took it to a local tire shop and the guy took the tire off. he doesn't think the wheel is bend nor its burr. we saw some flaking of the chrome rim on the inner ring. the chrome plating is coming off. he scrapped it and more came off. he suggested to replace it rather then sand it down. i really don't want to spend $ on a stock rim. any advise. thanks.
PR FIEBRU
Wheels, Tires & Brakes Forum
03-12-09 04:54 PM
