BRAKE SYSTEM?pic
Sup my CL bros!
I need new rotors & brake pads.
U like?
If not what kind should I get?
I would like 2 get some that do not rust!
Can I use OEM brake pads with rotors like this?
ty
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
U like?
ty
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Drilled rotors are a joke. They have the lowest friction, lowest strength, lowest capacity to store & transfer heat...
Don't buy slotted rotors, you don't race on a road racing circuit. Your brake pads are not going to melt, so you don't need them to be scraped a thousand times a second.
Stick with Brembo blank rotors, Hawk HPS pads, & flush the fluid to dot4.
All brake rotor's rust... They're ferrite.
If it worries you that much, go buy some high-temp paint and paint them. The brake pad will clean off any paint in it's way instantly & anything left will be incenerated the first time you hit the brakes.
I used aluminum duplicolor high-temp paint two years ago, still looks pretty good.
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
