Stock Radio
Hi, I just registered as a new member and am excited about the new forum to get information on my car from similar Lexus Enthusiasts.
My stock radio's volume control/power **** came loose and broke. I heard it is the Ribbon Cable but my volume control doesn't work nor can I shut off my stereo(even manually without the ****)
Can someone tell me if they've had any similar situation as well as how to take the stock stereo out of the dash?
Thanks, highly appreciative.
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Same thing happened to my mom (when it was her car)
Went to Lexus, they gave her a new one, even put it in for her.
To take it out, you hafta take out the ashtray, there are two screws there, maybe 4, i forget, take em out. Then slide the radio downward a little bit, pull it out. If you are tryin to do a head unit swap, you gotta custom fit a piece of plastic and make your own mounting kit and figure out the stock wiring harness...good luck, its hard. ALso, if you are doing a swap for an aftermarket, underneath the passenger seat is the factory amp, thats gotta come out too, i think...i took mine out because i put aftermarket amps in also, whatever, later...
Guest
Posts: n/a
I have a 1993 es300, does anyone know what sizes are the front speakers on the doors and whats the size of the rear speakers?? I want to change them all with aftermarket ones. Is it better to keep the factory amp or switch to an aftermarket amp if i do this??...thanks
