Tranny bolt location? 97 ES 300
Just wondering where on the Tranny is the bolt to drain the fliud... I could be possibly doing this tomorrow so i need to know where it is... Thanks
Tony
Tony
Your ES is like my RX; under the driver's side front is a black flat pan with a 10mm allen hex type silver plug. I'd recommend a 10mm hex allen with 3/8 or 1/2 drive from Sears. Should be Type-IV Toyota fluid...3.8 quarts on a drain and fill...
Tony,
The plug will have an aluminum washer, be aware not to drop it. If you have a torque wrench, tighten to about 35 Ft Lbs. (wet, meaning lubricated) ...
I used a small metal kitchen funnel to pour the fluid in... it has a small end that fits nice into the transmission fill tube.
Start the engine, brake engaged, step thru the Park to 2nd and back to Park steps on the shifter prior to checking the cold level on the dip stick, with the engine running in Park.
A gentle reminder, check again when transmission is hot...
Originally Posted by Tammy
Tony,
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I just replaced about 3.5 qts into the tranny.. I checked it without starting the car and it was passed the hot mark because i had to drive to the parts store.... I started the car and went through each gear a little bit and now i need to check it but its raining.... I got a wet *** in the mean time
I have to say though i think the car started better and seems better already.... It sure didn't seem like 3.8 qts came out of the tranny? Thanks
Tony
Tony
I checked it again this morning since the car sat all night and the level was really thin around the HOT mark and alittle thicker at the COLD mark.... Is this overfilled?
All i did was drain all that came out and replaced with 3.5 qts
This was correct right? Please help..
Tony
Tony
Tony,
I wouldn't worry about the thick-thin factor on the dipstick. I see the same result when I check my oil, and I attribute this to the fact that the thicker portion of the old fluid (oil or tranny) settles on the bottom of the pan, and thus some of the fluid resides on the dipstick.
BTW, did you notice the ease in changing gears after the tranny fluid was replaced?
Originally Posted by lexusk8
Tony,
Thanks lexusk8
