Flapping noise on 02 ES300
Hello everyone,
Yes I am new here as this is my first post. I just picked up a 2002 ES300 used with 80K miles on it. Since it had higher than normal milage I got a deal on the car. It will be 4 years old in November so with that in mind I am having only one minor issue. When cruising at 35 mph above depending on what direction the wind is blowing from I am getting a flapping noise from the front of the car. It almost sounds as though it is coming through the vents. I checked the front of the car to see if the wind deflector was loose. It acutally was missing the back middle push bolt so I fixed it into place thinking that this was the issue. Nope. On the way home from the Lexus dealer I kept hearing the same noise. It has to be something simple that is loose but I can't seem to put my finger on where this odd noise is coming from. Is there anyone that has experienced something similar to this? Since the car has no warranty taking it to Lexus to pay top dollar to figure out something like this is out of the question. It does not effect the drivability of the car and the sound comes and goes as it pleases. It is noticably worse depending on which direction you are driving and will go away after passing 65mph on the freeway. Something has to be loose. Thanks for the feedback and I am looking forward to being a member of the forum!
Britt
Britt
Welcome to the club!
Why not call the dealer & bring the car in for them to have a look at it......if you just picked it up very recently, they shouldn't mind having a quick look at the car (call the sales manager to explain & get him/her to let the service manager know your coming by). Dosen't sound like it's major from your description. I've had to do that on a couple of cars I've owned & the dealer has always fixed the problem no questions asked & no charged. Chances are, the dealer might actually feel slightly embarrassed they didn't notice it when the tech saftied the car. Good Luck & let us know how it turned out.
Welcome! I'm thinking something plastic is flapping. One of the udnertrays, wheel well acess panel, if not a wheel well itself.
I ran over something not long ago that apparantly shot into my friver's wheel well braking a huge 3-4" chunk out of it. I thought I blew a tire when I heard the wind pushing it into the tire LoL! Chalk up another body-repair to my mad fiberglass epoxy skillz yo!
Originally Posted by Lexusfreak
I still say run the car back to the dealer.....sounds like it would take them no time to fix the problem.
Has anyone also noticed that there is a squeaking noise on the idle pully when the AC kicks on with higher milage ES300's? The dealer said that it just makes noise and is harmless. It is not noticable when in the car but when standing over the hood it is a noisy little pully. A little WD40 shuts it up for a moment but then later it goes back to making noise again. WD40 is only a cleaner and really is not a lubricant but it did help me determine what was making the noise by temporarily quieting the pully. WD40 was also used becuase it does not adversly effect the rubber on a belt as per their website. I guess my question is would White Lithium grease hush the pully (cheap fix) or do I need to pick up a new pulley or have the bearing replaced in the pulley? Thanks all!
Britt
Originally Posted by brittho
Hello everyone,
Britt
Britt
Originally Posted by koolaidman
some one didnt put back the plastic plug under on the splast gaurd
The hurricane missed the DFW area but this also meant that I was busy all weekend with yard work. I am planning on looking under for issues this weekend. Thanks for the help so far.
B.
B.
Ravencrave
09-09-14 06:32 AM
