NGK universal O2 sensor ( feedback)
I bought the ngk sensor and I found that it is shorter and narrower than the oem densor. I happened to intall it with the Y pipe down and found the bank two sensor almost completely buried in the bunk you can barely see the top of the sensor when you look into the hole of the exhaust manifold. The front one is better at least you can see the openings of the sensor protective shell near the tip of the sensor. So the bank two sensor might get less direct contact of the exhaust gas.
That is why I ask if anyone has the experience of Ngk or NTK universal sensor.
But according to the book this sensor is listed.
Well I think I might give it a try and post the result later.
