Yellow Film Tint for Factory Fog Lights Pics
For those asking about this Yelloy Fog Mod, I purchased a bulk 12"x12" yellow film from www.stickercity.com. Removed the factory Fogs, and cleaned them up real good.
Applied the film then cut them out after I got them to stick. re-installed everything. Here is the finished product.
Overall I was satisfied with the mod, I did also do the Fog Light mod, and noticed how the yellow beam dispersed more light around the road. Street signs can be lite up that the white stock could not do. There is some loss of light output but not much really 15%?
At night the yellow is not very visible from far, only closer is it more Yellow. I would recommend this mod to anyone looking for this same look. I will post some more pics when I get ahold a better Camera.
did you consider getting some yellow fog lights like mtecs or nokya before you did this mod? you prolly could of kept the lighting output, and maybe safer. was the tint meant to be used on headlights? nice mod tho
Originally Posted by Maxx941
I did but I wanted the yellow lens. The film can be applied on any lights Cut to fit
few questions.. 1. is this item sticky or need a glue or something? 2. 1 order of the yellow bulk film cut to fit would be 12" X12" right ($14.95)? 3. i dnt knoe if i mis-read it, but did u change ur fog bulbs also?
GOOD JOB over all.. cant wait to see more picx!!
2. Yes
3. No I did the factory fog light mod, able to switch them on at any point by themselves. Relay mod
Originally Posted by MCV20
"3. No I did the factory fog light mod, able to switch them on at any point by themselves. Relay mod"
can i have more detail on that please...
Just in case your wondering because i got a bit confused as well from the pics, pins 2,3,4 go to same location, pin 1 on the relay got separate 12v source I piggybacked from the cigg fuse.
really easy. Props to MASH835 for the writeup!
Hey Max, the pics of your yellow fog light mod look awesome. Did you remove the fogs by going under the front bumper, unscrewing a couple bolts, and popped the fogs out and away from the bumper? I may consider something like that for the fogs in my '01 ES
BTW are you coming to the Orlando meet this Saturday (11/5)? It's still on, and we're expecting more than 50 cars to show up that day. Would also love it if other ES's come out too
As for the meet, I might make it, but I'm actually tiling my bathroom up and putting up new walls Bad excuse but It needs to be done. Hurricane
Very sorry to hear you sustained some damage from Hurricane Wilma, but glad to hear you're well. I know S. Florida is going thru a rough time right now, but all that matters is putting your life back on order and starting fresh, so to speak. I totally understand if you need time to rebuild your area, but if you happen to catch a break and have time to come up for the meet, let me know. We are planning to raise funds at the meet in support of those down south affected by Wilma, so we are certainly looking out for one another in any event
