Dead foglights
Dead foglights
My fog lights are DEAD. I don't know what I can do (besides getting some new ones because THOSE WERE new ones.) I already checked the wiring. Nothing seems wrong. I checked the Fuse and it's still good. I checked the bulbs itself and they're still good. Is there anything I haven't checked yet?
Are they the original fogs or are they aftermarket?
Are you turning them on using the stock headlight stalk or another switch/button?
Do you have the headlights on when you turn the fogs on?
They're aftermarket 55watts. I'm running them on with the stock switch. They can only be turned on while the low beams are on. My ES uses the round shaped fogs, not the square ones.
Originally Posted by Tammy
You say they turn on with the low beams? Turn off with the high beams? Won't turn on by them selves? That is normal operation ... They are only turned on with the low beam headlamps.
boostedg
04-11-14 12:10 PM
LSfanboy
06-23-11 07:22 PM
