Front exhaust pipe leaks
I'm not quite sure what you mean, are you talking about the exhaust manifold at the front of the engine or are you talking about the piping before the cat? I have a leak right now right before the cat. The stealership wanted $600 for a fix, but I am looking into getting the parts from toyota.
I have all the factory piping before the cat and a re-worked borla cat back after it.
What kind of problem do you have, just a leak? Have you had it looked at?
for $1000 , i would said.. ask more that 1 shop. try to get a quote from the dealer to see what really problem is it...
i just had my Mid-pipe replace due to some leak (where is sounds nasty ) therefore i m luck to get a used one for a solara owner..
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
900-1000 is the normal cost for the OEM replacement y-pipe.
Personally, if money is a problem & the flex-pipe is broken, buy new sections off ebay & just have someone cut the old off & weld the new in.
