questions about my es300
ok i have a 98 lexus es300 and i have some questions about hooking it up. i would like some suggestions and info. i need some help because websites dont provide good enough info and i dont get enough time to do more research because of skool.
1) whats the max size rims you can put on it? can i put up to 22?
2) what could i do to increase engine performance?
3) how much does a wood grain kit cost?
4) if i put in new sound system, will there be a lot of space left in the center dash? should i put
a tv there to cover it up?
5) how much would it cost to put in air ride suspension? what's the best company to get that from?
6) the carpeting is kinda dirty. should i clean it or just put in new carpeting?
7) how much does 5% window tinting cost on all 4 side windows? how much does 20% cost for front and rear?
8) the locks on the doors have to be opened manually because the automatic lock is broken. how do i fix that?
9) what is the best security system out there? how much would it cost?
10) how much does it cost to redo trunk carpeting? how much does it cost to put it new leather seats?
11) how much would it cost to repaint the lexus a new green?
12) the ac sometimes gives off a weird smell. what can i do to fix this?
13) the rear bumper has a big slash mark on it. how much would it cost to fix that?
14) i like the lexus es300 but for some reason it reminds me too much of a toyota camry. i see potential in it but im not sure. should i hook it up or should i just get a different car?
Dysfunctional Veteran
Also, if you live in a place where it drops below 10 degrees regularly, Air ride is a No Go. you will bust the bags in the cold. they will freeze, and when rubber freezes, it loses its flexibility. i have a friend with an S10 here on fort drum that had that exact thing happen to him, at 10 below zero, i told him not to raise the thing, or his bags would blow. and they did, all 4 of em.
www.discounttoyotaparts.com
and DIY.
Hope this helps. and welcome.
triplecore
06-18-06 07:05 AM
