Wt and HP Ratio
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Here are some calculation. Though 2006 has HP ( horse power ) of 218 but it also has greator curb wt than other year vehicle . so I think ratio of the two gives very interesting result .
Year -Wt curb - HP -HP/WT
2005 -3472 -218 -0.06
2004 -3344 -210 -0.06
2003 -3432 -210 -0.06
2002 -3432 -210 -0.06
2001 -3344 -210 -0.06
2000 -3344 -210 -0.06
1999 -3344 -210 - 0.06
1998 -3289 -200 -0.06
1997 -3289 -200 - 0.06
1996 -3366 -188 -0.056
1995 -3366 -188 - 0.056
( A NEW MEMBER . FIRST POST )
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
That's the reason they all run a 16.0-16.4 second 1/4 mile.
Most of them, by the time you add the fact almost everyone has audio equipment, rolls with baggages & most epeople can't drive one down a track - run a 16.5-17s 1/4 mile time.
A good driver with a little weight reduction & general mods can crack 15s in any of the A/T's, or crack into 14s with a 92-93 M/T.
1992-1993: 3362 - 0.055
1989-1991: 3164 - 0.049
The calculation isn't exactly interesting unless you're doing something with it.
http://www.stealth316.com/2-calc-hp-et-mph.htm
Geoffrey Fox's Formula works spot-on with the Camry platform until you build a few hundred extra horsepower. Keyword in that sentance is few. Forget the other formulas - they're way too fast for heavy DD-USD-FWD cars.
I think the ES250's published curb weight is way too high. The gen2 Camry v6's only weigh like 2800-2900lbs & I simply doubt they added 200-300lbs of material to it. It's too much the same as a Camry. Anywho 250's are quicker than they look on paper down a 1/4 mile. They're a high 16s car in good condition & someone with willpower could make a 13-14 second car out of one easily.
1992 Lexus ES 300 8.6 16.6
1994 Lexus ES 300 8.7 16.6
1995 Lexus ES 300 8.4 16.4
1997 Lexus ES 300 8.0 16.1
1995 Toyota Avalon 7.8 15.8
1995 Toyota Avalon XLS (auto) 8.5 16.5
1983 Toyota Camry 12.6 18.9
1988 Toyota Camry All-Trac 11.5 18.3
1992 Toyota Camry SE 7.7 16.0
1992 Toyota Camry XLE 11.2 18.2
1993 Toyota Camry LE 11.0 18.2
1994 Toyota Camry SE Coupe 8.1 16.1
1995 Toyota Camry LE 8.0 16.0
1995 Toyota Camry LE V-6 (auto) 8.4 16.3
1998 Toyota Camry LE V-6 (auto) 7.8 15.9
1999 Toyota Camry Solara SE 7.1 15.6
http://www.albeedigital.com/supercou...0-60times.html
Welcome to CL.
Welcome to CL.
![Hello](https://www.clublexus.com/forums/images/smilies/hello.gif)
Not down a 1/4 mile or highway. It would be faster once it got up to around 130.
2000 ES 300 - 3392 pounds - 8.5s - 16.5 - 0.061
Technique
06-20-07 05:09 PM
robloc93
06-01-05 12:26 PM
