20" RIMS QUESTION
Old 01-09-06, 10:53 PM
ari07
ari07's Avatar
Default 20" RIMS QUESTION
I've finally decided to put 20's on my car after much debate. I have a 97 ES and I know that the bolt pattern is 5x114.3 and the offset is 42, but my question is can other circle patterns such as 5x4.5 fit on there with different offsets such as 30. I was looking to purchase some rims off wheelwarehouse.com and they said that the pattern is pretty much the same and they can warranty a fit. WTF??? I don't understand how they can fit. I'm pretty clueless right now as to how this circle pattern will work. I don't know much about rims except that a set of camber kits can be used to correct the offset. Oh yea, I know there are alot of people that are haters for 20's on an ES so please let's not make this into another one of those "you shouldn't do that to your car" thing and keep the cynicism to a minimum. On that note, SOMEBODY PLEASE HELP!!!!
Old 01-10-06, 08:18 AM
young's 96
young's 96's Avatar
hey man i have 20's on my 96 if you want it get it but i will recomend you to use the 225/35/20 I have the 245/35/20's I cant wait till they are m.j. bald so i can get the 225/35/20"
Old 01-10-06, 10:17 AM
GATO
GATO's Avatar
IF you are going 20's on a 97...then the widest you would want them would be a 7.5
bolt pattern is 5x114.3 thats that.
as far as the offsets...........no camber kit fixis offsets. the offset is what determines how far in or how far out the actual wheel will fit. ( not the wheel barrel but the actual wheel design)
anything more than a +42 offset will most likley rub the strut tube.
I would stick to an offset in the 30's since it's going to be a straight 7.5 all around. that way you don't have any big rubbing issues.
on 20's you will need some fender modifications. no big deal...just some minor fender roll
Old 01-10-06, 07:07 PM
MoreMGD32
MoreMGD32's Avatar
yea gato is right, ive got 20s on my lex.
5x114.3 is what ya got, no changing it
you def wanna go with a 225/35/20, thats what i have and i still have some minor rubbing. Not bad but its still there, also kiss having more than 3.5 ppl in the car while your driving
its worth the sacrafices tho, ill tell you that much
peace
Old 01-10-06, 10:54 PM
ari07
ari07's Avatar
I thought the bolt pattern was different, but actually 5x4.5 is basically the same as 5x114.3, but just in inches and it's close enough. I know a 7.5 is recommended and will be a much better and safer fit, but I'm gonna go with a 20x8.5 though, I want that extra inch in width; it makes a big difference look wise. I don't have to worry about rub, I got bags anyway.
Old 01-12-06, 11:48 AM
NJLEX20"s
NJLEX20"s's Avatar
i roll 225/30/20 def would not recoment that for every day driving but the look realy cool go wit a 225/35/20 if your gona roll it every day.
Old 01-12-06, 12:42 PM
Pheonix
Pheonix's Avatar
Cool
Ick 20's.
To each, his own.
http://www.toyotanation.com/faq/all_...og=1&lang=en#7
Question:
What is the bolt pattern and stock wheel offset?
Answer:
Gen2:
Bolt pattern: 5 x 100
Offset: +38mm
Gen3:
Bolt pattern: 5 x 114.3
Offset: +38mm
Gen4:
Offset: +38mm
Gen5:
Offset: +50mm
thepheroe
02-10-14 01:40 PM
Iansaltes
10-17-07 12:35 PM
Bigbea
02-17-07 09:25 AM
LeXoGs400
Wheels, Tires & Brakes Forum
03-01-04 01:21 AM
Quick Reply: 20" RIMS QUESTION
