Low output Radio
Low output Radio
The Sound System of my 93 ES 300 outputs very low and does not turns off as desired. The rest is normal. I have read something about a booster amp located down the seat or the Package Deck. Help please.
Power-Volume Button Wrong
Yes Lexbox, I suppose it's everything stock
Regarding the volume button, when I purchased this ES 300 one month ago, that button was absolutely loose. I pulled it off and realized that the switcher behind it, it was unscrewed.
With a lot of care, I screwed it again and finally attached the button. Most likely I guess that the problem is related with that button, wich doesn't operate at all. For example: If I disconnect the battery and reconnect it again, and try to turn on the radio using that button, it doesn't start the radio. Then I must push any of the other buttons, ie: Serch, CD Changer, Cass., etc. to start the Sound System. After that, if I try to turn it off, no way.
Thank you for your help.
Santiago
Santiago
caddyowner
07-22-10 06:58 PM
nomoon
09-01-09 08:57 PM
