still rubbing with new struts
i just had my old stock struts replaced with KYB GR-2s but my car still rubs around turns with people in the back. i know i have wider SC430 wheels but is there no way to eliminate the rubbing problems? i already have spacers just to make them fit. i was even thinking about lowering the car with springs but it already rubs. would stiffer springs work? they're still on stock springs. is there anything i can do?
Originally Posted by ChrisES
225/40/18
when my car was on the lift i looked under and the wheels were less than an inch from the struts! do you rub with five people in the car?
Less than an inch? Tons of space! The wheels on my GS are 3mm away from the front suspension upright!
As long as there is a little clearance, you're okay. The strut moves up & down with the wheel/tire, so as long as there is a little clearance it should never touch.
My guess is that the 18x8 +50 SC wheels don't fit the rear of the ES at all without spacers. I have tested 18x8.5 +40 and it does not work on tha back of the ES. An 18x8.0 +50 is 4mm MORE inboard than the 18x8.5 +40 that I tested and did not fit.
First, he needs to determine WHERE and WHAT is rubbing.
Get 3 of your heaviest buddies and have them sit in the rear and check it out.
BTW, You really should check the clearance while the car is on the ground, not on the lift.
welcome to the world of lexus mods...they add up in a hurry.
replaced struts with coilovers $1200 installed
put on new wheel and tires $1900 installed
replaced rear sway link because of lowering the car noticed it was loose $69 installed
replacing front lower control arms because of lowering $350 installed
replacing both half axils because of clicking in cv joint after lowering $ ?? who knows.
