Car wont start just clicking noise, help
Old 03-28-06 | 12:01 PM
adhana2's Avatar
adhana2
Default Car wont start just clicking noise, help
I tried to reset by ecu, by pulling the EFI relay, once i put it back in now my car wont start, it just clicks when i tried to turn it on, any help would be appreicated thanx
Old 03-28-06 | 12:06 PM
vin 78's Avatar
vin 78
Depending on the "clicking" noise, Its probably either the starter or a nearly drained battery.
While turning the ignition key:
A long continuous clicking sound will likely be the battery.
And a singe click will likely be the starter.
Old 03-28-06 | 12:09 PM
adhana2's Avatar
adhana2
its continious clicks, but i dont know if its the battery or not
Old 03-28-06 | 12:10 PM
vin 78's Avatar
vin 78
Did you pull off your battery terminal when you pulled your EFI relay?
Double check your terminals and make sure its tight.
Old 03-28-06 | 12:11 PM
adhana2's Avatar
adhana2
yes i did pull the terminal, but it could be the starter, i am gonna check the battery
lexxygirl
08-15-10 03:04 PM
sfrhack
01-23-10 05:41 PM
elucid8
Performance & Maintenance
11-15-07 08:06 AM
shaitaan
06-21-06 10:41 PM
kino1161OLD
Maintenance
12-12-03 04:20 AM
