92-96 headlights
I tried to remove the headlights off my 92 es today but i couldnt find the three screws you have to unscrew. any one have pics? i tried doing a search put couldn't find any
You have to remove the plastic shroud between the two headlights that also covers the tops of the headlights. They are held in by I beliebe about 5-6 push tap type plastic pins. Once you have the entire shroud off you will easily see the bolts to remove the headlight.
Tonyucf20
20
01-07-17 10:45 PM
