fog light rewire need help
i'm trying to do the fog light rewire mod but i having a few problems.
I'm trying to run a wire from the coil side of the fog light relay to the taillight fuse so that i can turn the fogs on with my sidemarkers.
i found the foglight relay but i cant get behind the wires so i cant tap into it. its packed in the corner of the kick panel. is there anyway to remove that foglight relay holder and get better access to the wires that lead into the fog light relay?
i've done a search and havent found too much concerning 92-96 model.
if you've done this mod, please chime in and help
thx
thx
sounds like you are going to too much trouble. All I did was extend my wires and plugged them into the orignal hole except the one that leads from the batt. I just shoved that wire into the yellow fuse directly below that. I've been riding with it like that for months and I haven't had problems.
The effect: I can turn my fogs on/off when I desire except with high beams on.
