HVAC fan stopped working - possible causes?
Old 04-10-06, 06:32 PM
RedRacer
RedRacer's Avatar
Default HVAC fan stopped working - possible causes?
The HVAC fan in my 1997 Lexus ES300 stopped working today I checked the fuses and everything is fine so I can only assume that the fan motor has died. Are there other parts I should check before ordering a new fan? Is this a common ES300 problem?
How many labor hours to change the fan? Where can I get a good deal on an OEM motor?
Thanks
Old 04-14-06, 01:14 AM
abrarcool
abrarcool's Avatar
maybe u should try giving it external 12v from the battery and see if it works
there are a bunch of relays that kick in the fan when the ac is turned on or the temp sensor is hot
check relays
JettCRX
RX - 1st Gen (1999-2003)
18
05-31-22 07:46 PM
zero44
GS - 1st Gen (1993-1997)
10-23-14 01:14 PM
Macgyver
09-04-08 05:51 AM
jl300
07-20-03 12:09 PM
Quick Reply: HVAC fan stopped working - possible causes?
