springs / abs
springs / abs
I put springs (lowered 1.8") on the other day. Now the trac light is flashing and the abs light is on. I pulled the battery cable to try and reset it but had no luck. The wires at the wheel are all connected. Any suggestions?
1998 es300
1998 es300
This happened to me a few weeks ago. I was taking off my rear suspension and my dumbass took the 3 bolts off the top mount and boom my disc goes crashing to the ground. Speed sensor went bad and had my mechanic fix it for about 3 bills. Not the cheapest mistake I’ve done. Apparently the wiring is very sensitive and any tight stretch will make it go bad.
same thing happened to me last year when i put in my aftermarket suspension. here's my old post https://www.clublexus.com/forums/sho...abs+trac+light
not unless you can prove that it failed on its own or as a result of a Lexus technician. Most likely they'll say that you or whoever does your mechanical work caused it. Speed sensors are relatively delicate but difficult to damage unless you've go your hands in an area where Lexus doesn't think you should.
Maca1281
04-22-24 01:54 PM
