Low Budget DIY Solution for Burnt Out Needles
#136
Lexucanafer
I really like the simple solution in this thread, but I'd like to take it a step further to get the "factory" look. I'm looking at the red-tipped needles as a secondary solution if there's no way I can get the needles fully lit without spending lots of money and being without a gauge cluster for weeks.
#137
Thanks again for the extra information. I'm going to give the EL wire a shot, I think (just ordered the wire and some LEDs for the backlights.) While I have it apart, though, I might as well have some LEDs around to go with your solution if the wire doesn't work. Once again, thanks for your help and information.
#138
Lexucanafer
Thanks again for the extra information. I'm going to give the EL wire a shot, I think (just ordered the wire and some LEDs for the backlights.) While I have it apart, though, I might as well have some LEDs around to go with your solution if the wire doesn't work. Once again, thanks for your help and information. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#140
Okay, guys, just to give an update here:
As many people in this thread have mentioned, you need an inverter to run an EL wire. There are many large inverters that will take a 12v input to run many feet of EL wire. This is unnecessary. I am now looking at put EL wire in the needle itself, and putting a small 1.5v inverter (such as http://www.coolight.com/product-p/cl-imc-1.5ft.htm) in the gauge cluster itself and using another piece of equipment to drop the 12V DC voltage down to the required 1.5v using something like this: http://www.national.com/mpf/LM/LM317.html#Overview
Let me know what you guys think about this idea.
#141
Lexucanafer
Definitely sounds like an interesting project. It would probably be a good idea to start a new thread specifically for it, so it doesn't get confused with this DIY. Good luck, and keep us updated with your progress.
#142
I just finished putting LED's in the needles in my ES300 thanks to this post. I ruined the first couple of LED'S while I was learning how to solder them, but once I figured that out the job went very well. The first needle took about three hours, and the last one took about 20 minutes. Thanks for a great fix Lexucan!
#143
Lexucanafer
#145
ok this is an awesome project. i love the look of the lit tips better then the whole needle. I already have the leds and the resistors. I may attempt it this weekend if I have time. Thanks lexucan!
#146
Lexucanafer
#148
Lexucanafer
I just got the backlight bulbs, resistors and leds for the gauge needles and wow, those leds are small. At first I thought I got the wrong ones. I compared them to the pics of the ones posted here and didn't think they would really be that small. I think I got a headache from straining my eyes trying to look at them and see where the contacts are on them.
I think I'll need to order a magnifying glass before I tackle this project!!
#150
Lexucanafer
I think I'll need to order a magnifying glass before I tackle this project!!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
