Low Budget DIY Solution for Burnt Out Needles
#46
OK, I'll contact them. So, the idea is I buy the product from them and have my mechanic install it. He'll be happy, esp. if he needs me to send his kid to college! Thanks.
Any other ideas?
Any other ideas?
#47
Lexucanafer
No, actually the idea is: you remove your instrument cluster and send it to Lextech. Then they do your needles and/or backlighting and send it back to you.
#48
Rats! I got excited for nothing. I don't have the ability to remove the cluster and don't know anyone who does. Also, I'd be without for an extended period. Could I still drive the car? Guess I'll just need to watch it get worse until I think of something else. Thanks anyway!
#49
Lexucanafer
I believe you can drive the car without the cluster but then you'll have to reset the Airbag light once the cluster is reinstalled.
#51
Hi Lexucan/BadViper,
I am really interested in doing this mod to my ES but am a little scared about throwing the weight of the needles off and causing inaccurate readings. I was wondering if the snag you had BadViper was fixed and if so how?
Thanks!
Thanks!
#52
First of all, All praises to Lexucan for figuring this out.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
The balance issue only affects the temp needle and gas needle(when the car is off it sinks to empty then goes back to normal when I start driving). And there is no real difference in the tachometer and speedometer. I haven't fixed them truthfully because it isn't a real problem or anything to worry about.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
And don't be afraid to try this, think of it like this, if your needles are already burnt out then you have nothing to loose!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#53
Lexucanafer
So, after you have done the mod, leave the window off when you put the cluster back into the dash. Then you can test it and make any adjustments necessary before you pop the window back into place and button it up.
Hope this helps.
....and thanks to BV for the props
#54
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
I'm sorry but there has to be some type of resistor..even if they are built into the led itself, which I doubt because of the size and the year they were built. The resistor adjusts the amount of current that flows through the led. Without it the inrush of current would blow the led so fast that you would not even see it light...the led will draw as much current as possible, that is why the resistor is put into the circuit.
Yes I will provide pics of the whole manufacturing and install process...
I'm in the same boat & was thinking on a used cluster or a $175 + shipping repair until I bumped into the GREAT thread ( THANKS LEX !!!
#55
Hi, I just did some fixment on my 93 es, I replaced 2 long needles and 8 T6.5 1W super white leds. https://www.clublexus.com/gallery/sh...=76973&cat=500
#56
I have really enjoyed following these posts for the needle fix and backlighting upgrade. My two 1992 ESes both have these issues and being somewhat mechanically inclined I plan to try the DIY fix. Upon starting my purchasing I run into a question on the SMD (LED) to use. I am only finding 3 volt units, but seems I should be using 12-14 volt ones? Thanks for straightening me out on this.
#57
Lexucanafer
I used 2V surface mount LEDs for my DIY needle fix. I purchased them at www.digi-key.com
If you go to their website and enter L62401CT-ND into the part search box, you will see an example of one similar to the type I used. Unfortunately, the exact part I used is no longer stocked at Digi-key but the part number I gave you is a reasonable alternative.
Hope this helps
#58
Thank you for the guidance. I have done a little more electronics research and see more how this works now. It is the "forward voltage" that matters and the resistor match-up keeps this within the proper range (I think). I will certainly use the reference you provided.
P.S. Like these cars so much we have a 2000 also...just can't seem to boost income to the "buy new" level (3 in college and one more on the way will keep me this way it seems).
#59
hey.. is there any way someone can make like a parts list for everything... the wire, the resistors, and the smd's.... the digikey site is slightly confusing... not really showing any picures im kinda outa luck.... or links to everything.... i really want to do this and am good with soldering so i think i will try it out... just need the parts to do it... and also anyone know where i can get the t6.5 1w led...in the picture above....
#60
Lexucanafer
Digi-key p/n: L62401-ND
QNTY NEEDED: 4
THRU-HOLE 330 OHM 0.25W 5% CARBON FILM RESISTOR
Digi-key p/n: P330BACT-ND
QNTY NEEDED: 8
WIRE KYNAR INS 30AWG BLACK (100') *
Digi-key p/n: K394-ND
QNTY NEEDED: APPROX. 8"
* The wire you might be able to get at RADIOSHACK in smaller quantity than 100' - any fine gauge wire will do.
