Busted radiator
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I have plenty of times, it's fairly easy.
Just be sure that you get a 92-93 radiator only. The 1mz-fe went to a pressure capless radiator. Some people try to pass that off as the same thing - which will cause you to overheat.
Replace the thermostat & pressure cap on the intake manifold while you're doing it.
Flush the cooling system with some cleaner & a garden hose. Flush the pee out of it. If you poped a radiator, it's because the coolant <at some point> has been in there long enough to gel up & turn corrosive. It'll be nasty.
Otherwise... take the fan & shroud off the radiator, unclamp the hoses & unbolt the top of it.
Then pull strongly.
If the radiator has gelled coolant in there - it may weigh 40-70lbs instead of 20-30.
Then pull strongly.
gs2impress
GS - 1st Gen (1993-1997)
10-22-10 02:53 PM
