95 ES: high pass filter on rear channels?
Hello,
I replaced my rear 6x9 with a pair of Polk 6x9 3 ways, I took out the tweeter and mid so I am just running the rear channels to a pair of woofers. However, I found no improve in bass response. Same flat low end as before.
Before someone tells me to get a sub to get good bass, I want to emphasize that I only want to improve low end from stock, not going all out.
My question is: Are there high pass filters embedded in the stock amp rear channel? The speakers are not hitting the low end at all.
TIA
TIA
Buy an amp for the 6x9's.
The simple fact is you've still got a factory pioneer amp that can't push but 15-20watts max on that channel. By upgrading, you've lost the bad (but sensative / low power requirement) paper speakers & traded them for some that will bearly wake up when the factory amp is maxed out.
Most descent 6*9's really want 30-40watt RMS for general playing. Not like, 5-10watts.
You an do great sub setups without them costing much & still retain your trunk.
Otherwise.... Ditch the 6x9's, cut out the deck & install some *real* midbass drivers. Kicker SMB8's rock. I loved mine. No, there is no high pass filter. You're just not driving the 6x9's.
It's a pain... But you can cut the dek out & mount your deck speakers in a small closed, or ported enclosure & they'll sound infinately better. Just do the math on volume & port size if you're going to try a proted enclosure on them.
They're driven harder? Balance? I don't know.
I don't *like* telling people to spend money, but go spend alittle money LoL!
You can buy used single channel 150-250watt amps on ebay for like $20-40usd & a wiring "kit" for $10-15usd shipped.
WTF Sheesh you try to help people... You screwed it up, You didn't do your own math. So don't take it out on me.
The FSM, tells you everything you need to know. RTM
The current polk lineup of 6*9's (as searched off google) all want 100watts RMS. That amp puts out roughly 20 watts peak per channel.
Buy an amp, buy a big head unit, or keep suffering - that's the bottom line.
Good luck with that.
WIMPWGN, did you ever get this solved?
The efficiency of the polks seem to be 91db and 93db depending on model at 4 Ohm average impedence. If the efficiency is 1db @ 1w/m, then I don't get how they couldn't be playing nicely, as in amount of bass. Did you try readjusting the front/back balance?
Their frequency response goes down to 35hz, again not sure what the differential range is for that, +/- 2db or something. Everytime you double the power, volume should increase by 3db, so if the stock radio puts out 15W, you should have lots of volume. How loud do you turn your system up and what sort of bass are you trying to feel/hear?
darden
08-16-21 10:12 AM
Ag02M5
08-08-02 08:55 AM
