reseting the temp gauge-99 es
You need to replace the coolant temperature sensor. Unfortunately I can't help you out on where it's located on your car, but if you do a search for "temp" or "temperature sensor" in this forum, you may be able get your answer there.
I gave you the wrong terminology, I don't know why I was thinking of engine temperature instead of the outdoor temp. In any case, it's not the coolant temp sensor; it's most likely the outdoor temp sensor but I'm not sure what the exact part is called. I can't find anything here in this search engine, so maybe you could call up the service dept of your Lexus dealership and inquire about the problem. If anything, I would let them do the work in getting the problem fixed but if it's something that you can handle, then you're on your own. Good luck.
mjr955201
Performance & Maintenance
06-08-16 12:29 AM
