DIY: tightened the throttle cable...no more hesitation now!
it was the same on my 98 gs4, you step on the gas, and it takes a second for the engine to respond. So i decided to look under the hood, and sure enough the throttle cable had a lot of play in it. So i tightened it all up and no more hesitation!
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Don't worry about it. If it's idling correctly, the idle valve has it. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Same thing happens with the accelleration (throttle valve / kick down) cable to those that have one i.e. you.
https://www.clublexus.com/forums/sho...ght=kick+cable
I'll do the same for my 1996 ES 300. Thanks for the tips on the throttle cable...
ml30306
05-28-16 07:40 PM
Lukas99GS
01-12-14 03:28 PM
bbqness
07-08-12 03:27 PM
