how do you remove headlight on 02-05?
How do you remove the headlight from the 02-05 ES300. I removed the 3 bolts from the top, but how do u get to the 4th bolt on the side? Do you have to remove the splash guard or something? Thanks for your help
You would have to go through the splash guard. I remember that I had to go inside the wheel well to get that side bolt off when I replaced my parking lights. Once the bolt is off, the assembly needs side out towards you (you facing the car head on). I'm not sure of the bumber needs to be loosened too because I was changing my fog lights at the same time. Hope the info helps!
greens14
SC- 1st Gen (1992-2000)
12-10-11 08:20 AM
