98 ES300 Speakers
I have 4 questions regarding the following. First I have a 1998 LExus ES300 with the Nakamichi speakers, though the rear subwoofer were stolen.
1. Could I replace the rear sub trunk mounted speaker with the standard speakers in a Lexus ES300?
2. Where can I find cheap Nakamichi speakers other than the dealer?
3. Does the year matter as long as the speakers are from 97 to 01?
4. Does anyone know any sites that would sell cheap comatible subs for a 98 ES300, I dont care about brand?
Thanks
Thanks
You can find some at www.taprecycling.net. (the place is located in Rancho Cordova, California) I think as long as the speaker fits, it's good. Ex: aftermarket 6 1/2s can replace 6 1/2s. As for the sub, I guess the matching size of any brand is compatible.
you need to find specs on the speaker that used to be there and then match it. if you can't match it find out the specs of your amp and learn about audio engineering and match another speaker to it that'll work with it.
if you just try and replace a speaker that is the same size you'll run the risk of blowing your speakers and or amp. you have to match the specs up with the system you're running.
