Engine Not Idle After Install New Battery
Model ES 300 (1993) with 80K miles:
Battery failed (original battery). Installed a new battery and engine starts fine. However, engine will not idle when releasing accelerator ---just dies. Does anyone have any ideas?
I know of no security feature (other than the stereo and airbag systems) that would care that the battery was disconnected.
I checked for disconnected or cut vacumn hoses, wires, etc.
I did have maintenance done a few days before the battery died: one CV boot was replaced because it was found defective during a state safety inspection.
Coincidences do happen but this is weird.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Dont worry when you disconnect your battery and then reconnect it takes the ECM (computer) some time to "relearn" everything.Normal! If it doesent clear up in a day or two I'd bring it to the dealer.
I could not wait for the idle to stop diving for zero RPM, so yesterday, I adjusted the idle speed to sustain 700 RPM; it works fine now. Just do not see the relationship between the battery disconnect and the idle fall.
The ECM "relearn" process should have a improvement trend, not dive for the deck.
One other thing is puzzling, the stereo system did not require recoding...it works fine. I thought the anti-theft system would lock out the radio/CD systems?
Thanks for the input.
You should NEVER touch the idle screw the Idle screw is set from the factory and should never be turned! The Raido is a good Question i think if you remove the raido and unplug it then you might have to recode.
I did not change any jets or fuel flow, just adjusted a physical linkage between the foot accelerator and the throttle assembly. It is effectively just like me holding my foot down on the accelerator a quarter of an inch.
The radio worked fine even though the battery went dead and I replaced it; that is more of a mystery that the other quirk.
Caveman
Caveman
lsteadman
Hybrid Technology
03-22-18 08:54 AM
dxerg3770
ES - 6th Gen (2013-2018)
46
03-15-15 08:16 AM
Dave Zorychta
10-02-01 07:55 AM
