93 300 keyless entry
Old 07-27-06, 03:33 PM
robins13
robins13's Avatar
Default 93 300 keyless entry
Hi - just bought a 93 300 and going throught it I was wondering if there is anything I need to do to get the keyless entry working. No battery so I got one and nothing. Is there some I need to do. thanks a lot!
Old 07-27-06, 07:18 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Check your "Remote" switch which is to the left of the steering column on fhe dash. If the remote switch is set to OFF the keyless entry button on your key won't work.
Oh......and WELCOME to the club!
Old 02-02-08, 05:13 AM
JennGirl
JennGirl's Avatar
Okay, so I'm a little lazy about prying apart the key fob, as I'm at work and would like to pick up the battery on my way home from work. Anyone know off-hand the size of the battery for the remote key? If not, no biggie...
=D
Old 02-02-08, 08:22 AM
Choas
Choas's Avatar
2 2016's I belive.
Old 02-02-08, 01:41 PM
3000's Avatar
If you go to the Lexus dealer, it should be free. The guy or girl at the parts depo should put in a new battery at no charge and it only takes like 1-3 minutes. (Considering there's no other customers at the parts depo)
Old 02-02-08, 01:48 PM
Choas
Choas's Avatar
Oh on another note if its like the gen. 3 fob you can also use one 2032 in place of the 2 2016's
Old 02-02-08, 08:14 PM
llcoolpass
llcoolpass's Avatar
two? I only used one battery wtf
Old 02-02-08, 08:48 PM
Choas
Choas's Avatar
^That means someone intelligent replaced the 2 2016's with 1 2032 since it is the same thing
Old 02-02-08, 11:50 PM
Lexucan
Lexucanafer
Lexucan's Avatar
The 1993 ES300 key uses only one 2016 battery. I know coz I just replaced mine a couple of months ago.
Old 02-03-08, 12:34 AM
maniax
maniax's Avatar
the range absolutely sux on the stock key remote
Old 02-03-08, 07:46 AM
92ES5sp
92ES5sp's Avatar
Mine too.
Old 02-03-08, 08:06 AM
Choas
Choas's Avatar
Then the gen 3 must have a different fob.
Old 02-05-08, 03:25 PM
Monkiee
Monkiee's Avatar
i dont even have keyless entry on mine. >.< you all are lucky if you do. my remote entry is there but i dont even have the original key
splitfire
12-08-09 04:06 PM
rcpeters
03-13-09 03:00 PM
itgrowsind
04-03-07 04:18 PM
JKH
04-21-06 06:55 AM
illson_2k
07-09-03 04:52 AM
Quick Reply: 93 300 keyless entry
