BANK 1 SENSOR 2 and more
This is the O2 sensor that is bad on my ES. Am I required to remove the driver's seat and lift up the carpet to get at this sensor?? I can't find it underneath the car and I think in the manual it says I need to remove this seat. Also, which sensor do I get- is this considered the sensor after the manifold? (Anyone know the Denso part #?)
Also, when I am in park and or moving forward slowly and turning the steering wheel, I get a small clicking/grinding coming from the wheel. It doesn't seem like anything serious but I was wondering if anyone knew what this was...
Thanks.
Thanks.
As for your second question, do you mean a clicking/grinding sound coming from your steering wheel or from you front wheel?
If it is your front wheel(s), then raise the front of your car and secure it with jack stands as you have to stick your head under. Check the 4 rubber boots on your axle shafts. Look for rips or grease spraying out. The CV joints may be going.
steviej
steviej
