removing indicator warning lights
Hi,
Can someone plases tell me how to remove a warning light indicator bulb from the dash. The traction control light keeps blinking and I would just like to remove the bulb to prevent it from flashing. (I know that the traction control may still not work).
I tried doing a search but i dont believe this has come up before.
Thanks for any input
If the traction control light is blinking, then it's obvious that something is amiss with your traction control system. Did you also get a check engine light? If so, I would go to Autozone and get the error code(s) scanned and the problem diagnosed. It is a free service.
The car was involved in an accident. A whole bunch of lights came on, including the CEL (bad 02 sensor). Those porblems were fixed,. However, I don't feel teh traction control is that important, as it was off most of the time anyways. If I disconnect the batter it will go away, but eventually it comes back.
edit: I found instructions on how to remove the gauge cluster. Just need some intructions on how to remove the indicator bulb.
Thanks
Thanks
bofronado2
04-16-14 01:58 PM
