02 es300 serpinteen belt chirping?
is this normal for alot of chirping while idling? i noticed since i got my car it chirps alot and sometimes on a hot day after running the a/c alot, itll squeal while turning (only did that like twice btw), but i was in a drive through and noticed it was LOUD chirping this morning! what the rememdy for this? thanks again ppls!
It sounds like the serpentine belt may need to be replaced. These belts are just like any other wear and tear item; they degrade with age and use. Plus, the belt is made of rubber, which tends to dry out as the years and miles go by.
The belt is pretty easy to replace yourself. You'll have to loosen the locking and adjusting bolts which hold the generator and pulley together, which will give the belt some slack for it to be pulled off. Check out this thread for more info on changing serpentine belts. Good luck
like lexusk8 said, replace or tighten the loose one. Make sure you got no fluids leaking on either belt. Check them for dryness and cracking on the back side.
Incidently, I found it to be the PS belt in the winter that squeals a little in extreme cold, gone when the engine compartment warms up.
steviej
steviej
the belt seems alittle dry but theres no cracking. ive heard good things about the gatorback belt so i think ima grab that and just change it. one more question tho. it seems SUPER tight down there..... how in the crap does the belt go one easily like ever search i did says?!?! will i notice when i loses the tention??? seems kinda hard to me from the looks of it!
The serpenine Goodyear belts are call "Poly-V"
http://www.goodyearbeltsandhose.com/...tCarSearch.jsp
Search on the 2002 ES300 for the belt numbers..
They are accessed by removing the right front wheel.
copy, invest $20 in a Haynes shop manual for you 02 ES. www.Amazon.com
It will answer alot of you DIY questions.
The PS pump has to be loosened and moved to remove that belt. Then retightened to tension the belt.
The Alternator has to be loosen and retightened to remove the other belt.
steviej
steviej
steviej
steviej
mooseboy84
10-31-15 11:35 PM
DesertJake
06-13-15 11:56 PM
