View Poll Results: What kind of gas you use in ES?
Regular
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
134
42.54%
Plus
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
44
13.97%
Premium
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
137
43.49%
Voters: 315. You may not vote on this poll
Which gas you put in your ES300?
#92
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I have a 96 ES that I did some low test vs high test tankfulls a few years ago. Lost the exact numbers, but mileage did drop with cheapie fuel to point that it cost MORE to run the car on the cheapie blend then it did on 93 premium.
Also, performance and throttle responce took a clear hit downward, so I never run anything but 93. It's only $2-3 bucks a tankfull more.
Sorry I don't have the exact test data, but results were clear about the mileage, and I like the extra power
#93
Here is a page taken out of the 2007 ES Owners Manual which is exactly the same for '02 thru '06 ES's. It shows that regular grade fuel is completely accepted. You guys/gals that insist that premium fuel is the answer.....than keep dreaming, while I pocket the extra cash and spend it on things that give me much more satisfaction!
![](http://members.aol.com/amf1932/FuelRequirementsES350.jpg)
#96
Probally gonna get 250-300 range on cheap 85 closest to dealer and needed gas and dad paid for it. But gonna try and do 91. Utah sucks in the regared to octane ratings 85 87 91 at most stations with the execption of a few and the station right by the raceway which can get 111 unleaded
but then thats like $8-$12 depending on the season.
![Yikes!](https://www.clublexus.com/forums/images/smilies/yikes.gif)
#97
premium != best gas
premium = rating of how reluctant the gas is to detonate
!= means not equal to
regular will detonate more freely than premium because regular is lower rating.
if manual calls for 91, and says you could use 87, that is just saying that the knock sensor will calibrate for the fuel. however, the problem is, it does that AFTER the gasoline causes problems!! for engine longevity and fuel economy, use the ''octane'' rating they call for [not the in an emergency rating, i.e. 87], or higher.
#98
every owners manual for every car on the planet tells you to use premium. doesnt mean thats the only thing you should put in ur tank. i use regular. maybe if i had a new car it use plus or premium but even the regular aint cheap
#99
i only use 91 octane in my car...even though its more expensive...but if you think about it...a whole tank is about give or take 2 to 3 dollars more than regular gas...plus you get more mpg...and you gotta love the power (i redline my car at least once a day)...i have about 167k on my car right now and it is still running strong
#101
You should only put in what is specified in the owner's manual. Do you put water in your gas tank?
Maybe if you can't follow simple instructions (i.e. owner's manual), don't drive at all.
#102
i only use regular 85 octane. with the elevation in colorado studies say that higher octane makes no differance at this elevation plus gas here is bout 3.20 a gallon for the regular.
#103
owners manual specifies 87 or greater. so why not use greater? its cleaner burning, gives better performance, and proves better gas mileage (1-2mpg greater). I know this because I drive from San Francisco to LA every other weekend. Depends on how you want to run your car. 87 will suffice and is cheaper. There will be NO damage to the ES if 87 is used. 91 is best, is more expensive, and does NOT justify the COST difference of $0.30. 1-2 mpg x 17 gallon tank is 34 extra miles on a full tank but... ($0.30 x 17 = $5.10 extra per tank; gas for premium in LA is around $4/G). if your ES gets 28 mpg like mine with 17in IS rims, then u r better off using 87, filling up one gallon earlier, and u can be cheap. but like i said... it depends on driving preference
if performance is the concern... get 91
if mpg and cost is the concern... get 87
i use 91 even though I cant afford it
#105
I remember when my dad got his 2000 jeep cherokee the CA edition had 5 less hp than the same model purchased in another state... Not really relevant but just goes to show you that even amongst the states there could potentially be differences
I would listen to whatever your owner manual says unless u are heavily modified engine wise.
