HELP!Screech sound, shredded metal
Well last night i began hearing a clanking sound so this morning i checked the engine out. the sound was coming from the 2 belts next to the alternator. they sounded as if they were touching at some point. then there was a loud screeching sound from the belts, but i didnt get to look at the belts when the sound occured because i was next to the drivers door so i just shut it off. the belts smelled like they burnt a little. so next with my sisters boyfriend i turned it on again and the clanging sound seemed to be back and a small shredded piece of thin metal flew out. about 4x2 cm.
Anybody know what happened and is it a bad enough problem that i shouldnt drive it?
sounds like a seized tensioner pulley.slight chance of seized acc.see if you can tell what belt has a different look to it(from the burning),if you can start the car one more time check to make sure your acc work.do you still have p/s?is the battery light on?does your a/c work?i would bet on the tensioner though
wickedt
12-26-23 12:29 PM
gabzor
09-15-12 07:02 AM
