Motor Q's
Alright I bought an engine stand, borrowed a hoist and I plan on taking my motor out tommorrow after work and I was wondering if anyone knew what kind of problems that i would run into.
I blew a head gasket, getting that replaced is a tad bit expensive so I'm going to buy a new motor, the haynes manual for the camry gives alot of information but i would like to talk to someone that has done it before and know common problems etc.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Yeah you better check / replace all those gaskets on the used engine. You better check the radiator & anything coolant related on both engines before you wind up with another blown head gasket!
ok i was going to start today but garage was to messy but i'm starting tommorrow, oh another question has anyone heard of using the bottom end of a 3.3 or 3.5 motor and boring the cyl. to to fit the pistons, is this worth it?
They're completely different blocks. The coolant routing on the truck 3.4L 5vz-fe is also different, so you can't use 3vz-fe heads on a 5vz-fe block either.
Displacement isn't that important. It only provides a linear gain in power. It wouldn't be worth enouhg power to be worth the effort. It's not like a retarded american v8 where you can take something that starts @ 5.4L then magically add 20% displacement to it without even trying.
