Cornering lights on 97 ES 300
If you lift you the plastic sheild in the engine bay that covers the top of the headlight, you should see a little screw on a bracket that holds the corner and headlight together. Once the screw is removed you just pull the corner towards you.
This thread might also help:
https://www.clublexus.com/forums/sho...move+headlight
DCM
07-28-08 08:01 PM
DCM
07-25-08 09:43 PM
Dago
02-06-07 03:05 PM
