Fog lights on 2001 es300
so i have the fog lights but i dont think theyare working. they should work just by using the regular headlight **** on the left of the steering wheel right? you just have to put it on the right function am i correct?
I dont think my fog lights are working if that is right..
is there also a way to disable the front parking lights? the yellowish light that is on 24/7 when put taken out of "park"
thanks again everyone
Check with your owners manual.
The fog lamps only turn on when the headlamps are on and in low beam position on the selection stick.
The daytime driving lamps (DRL) are the high beam lamps at half power.
yea i really need to order a owners manual..
i bought it from a dealership, but it was a Ford dealership and they didnt have a extra key or the manual =/
Everything is unaltered and stock. as far as i know
so i believe it should be plugged in correctly
OKOK
haha I just found a little **** next to the selection stick that is for the fog lamps
woohoo sorry ^^
OKOK
woohoo sorry ^^
