All 4 Turn Signals Flashing Faster than Normal
All 4 turn signals flash very fast when activated for turning. However, when I apply my emergency flasher, they function properly. It started out with my right front signal flashing too fast. Then the left front started. Then both rear turn signals followed. Your replies are appreciated.
^^ I don't think it's a bulb problem at all if one bulb after the other is showing the fast flashing behavior. It sounds like something more inside the electrical system needs to be checked out like the fuses and wiring for the turn signals. However it may get complicated to try to trace the source of the problem, so you may want to consider bringing the car in to service for a check-up.
It's weird, because I had my corners cleared (self task), then my left signal was faster than my right, but it only did it for a week, all bulbs were not dead, then the week after, everything was normal.
Theres gotta be something in the wiring, Id say where the wire goes into the plastic piece that connects to the light would be the best spot to start.. just turn the signal on and pop the hood and wiggle the wires see if it does it then stops or what.. just dont burn yourself..
-Scott
-Scott
Read this thread about this subject:
https://www.clublexus.com/forums/sho...d.php?t=195238
This particular problem is very common and has been discussed numerous times.
