Recent Oil change
howdy folks...
Just finished an oil change with fresh Castrol Syntec 10W30
usually, I use a fram oil filter with every change, but this time I decided to try out a bosch oil filter.. A significant difference I see between the two are the tops because the Fram has better grip while to screw on the bosch one, you have to use a wrench to get a good grip on it.
What oil filters do ya'll usually use to change your oil? What are some good recommendations for some? What type of oil do ya'll use?
GOGOGOO
GOGOGOO
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Super Moderator
howdy folks...
GOGOGOO![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
GOGOGOO
As far as oil, it depends on a lot of factors.
Toyota filters are cheap & proven to have a very short list of comeptition when it comes to filtration rates.
NEVER use ANYTHING ****ing Fram. ****ing ****ing ****ing ****ing fram.
![](http://img.photobucket.com/albums/v414/Toysrme/PICT0058.jpg)
From makes the most CONSISTANTLY **** products on Earth. Atleast Ford makes the GT...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
HOLY S***!!!!
I've never seen a fram oil filter with a hole in the top O__O....wow...makes me think twice about using fram now
by the way, why is it that your oil filter is on the side of the engine? haha
while a lot of us(or just me) look at **** in our free time.. He spend his time upgrading and finding new ways to change the ES.. that's a Oil filter relocator. it's just give you easier way to change the filter.. pretty cool tho..
[QUOTE=Pheonix;2255287]Toyota filters are cheap & proven to have a very short list of comeptition when it comes to filtration rates.
Phoenix, you seem to know your stuff when it comes to engines. What about Puralator oil filters?
I used to use Castrol Syntec, but now use Mobil 1 Synthetic. I've read in several places (online) that Mobil 1 uses more and higher quality (more expensive) additives. I've also read a long term independent test that showed that Mobil 1 maintains viscosity better than Amsoil (Amsoil thickens).
shyishguy
08-22-07 07:12 PM
