oil level sensor
Anyone know what the oil level sensor looks like on the 93 es? I have a leak coming from my oil pan. It is coming out of what I think is the oil level sensor. It is a square block with four screws in it one on each corner. It also has a sensor with a wire clipped to it. I tried to take it out, I removed all the screws but then it looked like I had to twist it to unlock it and I stopped there. I tightened it back but noticed it is still leaking. My oil level light is also on. Anyone have any suggestions?
Thanks for the reply Pheonix. I figured thats what it was as it was the only one. I was wondering if I can just remove the sensor from the outside? It is attached with four screws. Is there some kinda seal on the thing that has gone bad that I can replace or should I just silicone the sorry thing to keep it from leaking? Not too concerned with the sensor not working correctly as I keep an eye on my oil anyway. But if it is an easy fix I wouldnt mind doing it as the light is pretty annoying.
