Wheel question
![](http://i53.photobucket.com/albums/g51/dinky1963dow/LexusES330004.jpg)
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I would really like to get your opionion on the wheels I have mounted. I have another set I can put on also. I don't care if you like them or not please comment. Thank You!
Those wheels make your car sit too high. If you plan on keeping them, then I suggest dropping the car down a bit. It will also help out with your handling, especially when taking corners.
Thank you for the comments so far. The other wheels I have I am not sure if they will fit, but I will know this spring. Any other comments are more then invited. Just give me your opionion like the prior 2 did. No offense taken!
If the wheel studs are not long enough, take one off and take it to the Toyota dealer (probably Autozone/Pepboys) and they should be able to match them up. That's what I did when I bought my first set of aftermarket wheels (wrong offset).
Good luck with that, and welcome to CL!
Benoit
Wheels, Tires & Brakes Forum
04-25-19 01:49 AM
