Future Plans need help
DO you even have HID's?
I had 6ks before and the glares unbelievable, supposedly as you raise the kelvin, the glare goes down, hopefully this is correct. And a 55-60w bulb does NOT have enough light output unless you're on a side road by yourself with no lights around you.
Also 10k's and 12k's are used in most mercedes so define "ricer"
I don't think Phoenix meant 55-60w bulbs...I'm not sure what the actual wattage on an HID bulb is, but you can modify the ballasts to put out a higher wattage (I think this is what Phoenix was referring to)
gerbjones
01-04-09 06:28 PM
