92 es300 buzzing turn signal
When I put on the left turn signal the indicator light comes on and doesn't blink then makes a buzzing sound. I checked all the bulbs and are all in good shape, none are blown and all come on. Any help is appreciated, thanx.
I have this problem too time to time. I think it's the circuitry to the speaker because when I told the dealer they wanted a couple grand for a new cluster. If I dont pull the turn signal all the way down for the left signal I get the buzz.M passengers and gf were like wtf when they first heard it.
i can see now that i wasn't the only one that have this problem. the buzzing sound is acutally coming from the flasher relay. the flasher relay controls your blinker . without the relay there will be no emergency signal or turn signal. [EX.]people whom put led in there turn signal experince fast blinking dude to the differences of power input/output. therefore buying led flasher relay will eliminate the problem. but thats a different story.
I haven't done anything to elminate the buzzing but i think getting a new flasher relay will elminate the problem. and i'll let you guys know and show step by step instruction how to replace it.
experince problems....
not fully turn left or right = buzzz
fully turn right and left swiftly = buzz
i was wondering if it had something 2 do with the relay! realy wasnt even sure if the car had a relay for flashers or some other type of circutry! thanx!
Hello,
Yes, solution was found.
The relay should be located to the left from the e-brake, big black box which should click once you turn on your turn signal.
Hope this helps and best of luck!
Hello,I have a 96 Es 300 buzzing left signal light stays green wont work i have light out. What do I need? A socket or relay? Thanks
