ES300 W/TSX retrofit pics..
#47
I was wondering if you couldn't just replace your halogen projector with an HID projector? Just open up your headlights and go from there. Have any of you 2nd generation owners done this? I would think that it would not be that hard.
#48
That turned out very nice!!!Mad props to ya
I was wondering what kind of ballasts and igniters u are using? Also are you using the stock wiring? I'm about to do a retrofit too but just need to do a little more research.
#51
Got some Ultra White White LED's forward facing only (illegal watts for street here) and the problem is that there is a casing in-front of the projector bulb which doesn't allow the LED's to work, all you can see is a white halo like the BMW angel eyes. Looked good, but no way it'd light up the street for driving :P
#52
As of now, I am using some inexpensive ballasts (with built in ignitors) that were purchased on the "bay". So far, it has been over 6 months of daily use and I have had no problems whatsoever with them powering up and igniting the bulbs. I am also using the stock wiring. Hope that helps you.
#53
Thanks for the reply, I appreciate it. I intended to use my stock wiring but after some research on hidplanet.com most prefer making their own harness. I might just go that route just to be on the safe side.
#54
I felt the need to bump this thread because this looks like a really nice winter project to try. I do have a couple questions on this tho. First why are there so many different ballast computers? What difference are they, what do they do and if i get a tsx setup is it better to go with tsx ballists. Oh and what kind of bezel do i need to cover up the projector? Last is it better to buy in pieces or a whole setup like this
http://cgi.ebay.com/ebaymotors/Acura...spagenameZWDVW
Oh and is it just me or is that her cleavage in the reflection?
#55
Oh and is it just me or is that her cleavage in the reflection?![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
#56
^hmmm ok so what projectors and ballasts do you recomend and is that a good deal or should I be able to do it for less?Oh and look at the top two pictures it looks like she is wearing a white low cut shirt you can see it in the projector. Also and bezels you recomend?
#57
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Going prices for items you need
TSX projectors: $150
Denso Ballasts: $150
Bulbs: Depends on what you want
Shrouds: from $5 to $50. Again, depends.
You can definately find better deals on these items or find cheaper alternatives but that is entirely up to you.
#58
So on another note with this has anyone been able to get the high and low beam function to work with out adding a new switch(use the high beam lever on the steering wheel) Oh and what about harnesses what kind would I need to get this to work.
