Shocks and springs
Hi I am posting this to get people's recommendations if it's worth putting on tokico gas shocks and eibach 1" lowering spring kit, or if there is anything better for a 94 ES, also what kind of air intake kit do u suggest I should put in, and if there are any sites to change the hoses to different color ones
thanks
brian
thanks
brian
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Maybe you should get some H&R springs the seem to lower more the Eibach and seem to ride better then intrax.If you get new springs then struts are a must cause your stock ones will not last too long(1-2 years max) with aftermarket springs .Here is a page for that hose http://www.mvpmotorsports.com/merchant/hose.htm you can get this hose in other places but this is the only one i remeber by hart.And for the intake the best thing you can do is make your own Custum cold air intake.here is a pge that can help you build and intake http://www.teamdelsol.com/howto/coldair/diycoldair.htm I hope that helps you out..
INSTEAD OF MAKING YOUR OWN INTAKE YOU CAN BUY A 3 INCH AIR FILTER ADAPTER AND THEN YOU CAN USE ANY BRAND OF FILTER YOU WANT. THE ADAPTER ONLY COST $12.99 @ WWW.TRADESONIC.COM-CLICK ON LEXUS AT THE BOTTOM.
FOR THE EIBACH SPRINGS GO TO WWW.RODMILLEN.COM-THE STORE LINK.
schef300
SC- 1st Gen (1992-2000)
04-24-10 04:08 PM
