ES300 intermittent blinking A/C Light
My A/C Light blinks intermittently and no air conditioning is available until I turn it off and select ON again. Then it operates for about 30 seconds to 2 minutes and starts blinking.
You might check your ac Belt. It is probably loose and slipping a little. Mine used to do that whenever I would hit a puddle. Once I had my belt changed it does not happen anymore.
You can check the A/C error code contained in your system by following the instructions in the link below:
http://www.lexls.com/tutorials/air/accodes.html
GUYS...check your AC filter...it must be dirty...i cleaned mine and it worked for me..AC filter is underneath the glove compartment...open the glove compartment and there is a screw on the bottom right...take it out and inside you will see two black hand screw locks on each side..take those out and drop you glove compartment down..the Air filter is right infront ..open the cover and pull the Filter out and vacum out the Dust..that should resolve the problem.
